You are here: MRFMRF2DDuplicateRemover
Deletes duplicated features. Features are considered to be duplicates if their geometries are within tolerance and only features with a smaller tolerance will remain after cleaning.
This transformer performs the same operation as the MRF2DCleaner with the Remove Duplicate Geometries set to Yes and no other options selected. See the MRF2DCleaner for more details.1Portions of this work are the intellectual property of the MRF Geosystems Corporation and are used under license. Copyright © 2006 MRF Geosystems Corporation. All rights reserved.
FME Licensing Level
The MRFCleaner transformers are available as an extra-cost package from Safe Software. Please contact sales@safe.com or call 604-501-9985.
Related Transformers
MRF2DConflator
MRF2DDangleRemover
MRF2DExtender
MRF2DGeneralizer
MRF2DIntersector
MRF2DJoiner
MRF2DShortGeometryRemover
Transformer Categories
MRF
Search FME Knowledge Center
