You are here: CalculatorsRandomNumberGenerator
Generates a uniformly distributed random number.
The random number is x, where Minimum Value <= x <= Maximum Value.
RandomNumberGenerator generates random numbers using the Tcl rand() function. The numbers generated by this function may not be considered truly random, because rand() requires an initial seed value, which determines the sequence of numbers that is generated. There are no more than 2^31 possible random number sequences, and these sequences repeat after 2^31 times. The same seed value, used repeatedly, generates the same numbers. Additionally, the sequence, by design, never produces the same number twice in a row.
Transformer Categories
Calculators
Technical History
Associated FME function or factory: @Evaluate, @Tcl2
Search FME Knowledge Center
