You are here: Coordinate SystemsGtransReprojector
GtransReprojector
Reprojects features from one coordinate system to another using the Gtrans reprojection library (from the National Land Survey of Sweden) and the specified translation file.
Dependencies
This transformer relies on Gtrans translation software which is included with FME on Windows platforms.
Raster Parameters
This transformer ignores the coordinate system set on input features, and does not tag output features with a coordinate system. If you want to take the output of the GtransReprojector transformer and write it to an output format that includes coordinate system metadata, you will need to specify which coordinate system to write, either by using a CoordinateSystemSetter transformer, or by setting the writer's Coordinate System parameter in the Workbench Navigator.
Transformer Categories
Coordinate Systems
Search FME Knowledge Center
Tags Keywords: SWEREF99 "National Land Survey of Sweden" Sweden
