You are here: RastersRasterExtractor
RasterExtractor
Serializes the geometry of the feature into the Blob Attribute based on the selected writer format.
  • Writer parameters may be controlled by setting format attributes on the feature. For example, when writing to JPEG, the compression level may be set via the jpeg_compression_level format attribute. Consult the writer format documentation for a complete list of supported attributes.
  • The RasterReplacer may be used to do the reverse operation and convert the encoded blob back to the original data.
  • Alternatively if the raster is not required as a geometry on the feature for future processing, the AttributeFileWriter transformer can be used to dump the Raster Blob Attribute directly to a file.
  • To carry out a similar operation on vector data, please use the GeometryExtractor transformer. For point cloud data, please use the PointCloudExtractor.
Transformer Categories
Rasters
Related Transformers
RasterReplacer
GeometryExtractor
GeometryReplacer
PointCloudExtractor
PointCloudReplacer
FME Licensing Level
Search FME Knowledge Center
