You are here: Geometric OperatorsSurfaceOnSurfaceOverlayer
Performs a surface-on-surface overlay so that all input surfaces are intersected against each other and resultant surface features are created and output. The output surfaces can retain all the attributes of the input features in which they are contained.
All surfaces are broken down into faces. For example, a mesh is broken into faces, one face per mesh part.
Non-surface input features are not supported. Input collections of surfaces are automatically de-aggregated.
Attribute Accumulation
Example:
Aggregates are not supported by this transformer.
Transformer Categories
Geometric Operators
FME Licensing Level
Search FME Knowledge Center
