You are here: Web ServicesGeoRSSFeatureComposer
Constructs GeoRSS documents from the input features and stores them in the specified attribute for the features that are output by the GeoRSS port. The constructed GeoRSS document will be created according to the specified Geometry Format and Output Format, in the character set specified by the Output Character Set parameter.
Transformer Categories
Web Services
FME Licensing Level
FME Knowledge Center
See the FME Knowledge Center for additional information about GeoRSS and FME.
Search FME Knowledge Center
