You are here: InfrastructureFMEFunctionCaller
FMEFunctionCaller
Calls the specified FME function, optionally putting the resulting value in the Result Attribute. This is a safe way to run FME functions in Workbench, as they are used in mapping files.
See the FME Factories and Functions documentation page for more information about FME functions.
Example
The @Reformat function requires a configuration line. To employ it within a workspace, the function would be called like this:
@Reformat(DestDecodeSrcEncode,BinaryKey,Company_Id)
and the configuration line which defines the "BinaryKey" binary structure would be specified as:
Reformat STRUCT_DEF BinaryKey_Part1 BigEndianInt(4,1) _Part2 BigEndianInt(4,5)
Transformer Categories
Infrastructure
Search FME Knowledge Center
