Interpolates labels along a linear or polygonal feature. Labels are placed at a regular perpendicular distance from the closest point on the line at some interval, and are given a rotation perpendicular to the line.
 Label
Label
                                            The label text desired on the output geometry.
 Prevent Label Overlaps
                                            If this parameter is set to Yes, labels will only be generated if they don’t overlap with other labels already generated by the same transformer. If it is set to No, overlapping labels will be generated.
 Label Position
Label Position
                                            The Label Position controls where the label will be placed relative to the original line.
- If Above or Left is specified, then the points are located the <offset> distance above (or, if the line is vertical, to the left of) the line. Above or Right is identical, except if the line is vertical then label point will then be to the right of the linear feature.
- Below or Left and Below or Right work similarly with all label points being below the linear feature unless it is vertical. If it is vertical, then the label points are to the left and right, respectively.
- If Right is specified, then the label is always placed on the right side of the line.
- If Left is specified, then the label is always placed on the left side of the line.
 Label Offset
Label Offset
                                            The labels will be placed Label Offset units perpendicular to the closest point on the line, where the offset is also measured in ground units. You can either enter a number, or take the value of a feature attribute by selecting the attribute name from the pull-down list.
 Labels at End Points
                                            This parameter controls whether or not labels will be placed at the end points of the line. If not, then the labels will start half the label spacing from the start of the line.
 Label Height
Label Height
                                            This parameter controls the height of the labels, measured in ground units. You can either enter a number, or take the value of a feature attribute by selecting the attribute name from the pull-down list.
 Average Character Width
                                            This parameter controls the average character width. If left as the default, 0.0, the Label Height will also be used as the average character width.
 Label Spacing
Label Spacing
                                            This parameter controls the interval of the labels. A label spacing of 0 will result in a single label being placed at the midpoint of the line. You can either enter a number, or take the value of a feature attribute by selecting the attribute name from the pull-down list.
 Minimum Length
Minimum Length
                                            This parameter sets a length threshold. If a line does not meet the minimum length requirement, no labels will be generated for it.
 Label Rotation Attribute
                                            This is the name of the attribute which will hold the rotation of the label. This rotation is adjusted from the orientation of the line so that text oriented at the label point will be parallel to the line segment and will not be upside down or right-to-left.
All rotations are measured in degrees counterclockwise from horizontal.
 Parallel Rotation Attribute
                                            This is the name of the attribute which will hold the rotation of the line itself at the point being labeled.
Example
Using a set of menu options, transformer parameters can be assigned by referencing other elements in the workspace. More advanced functions, such as an advanced editor and an arithmetic editor, are also available in some transformers. To access a menu of these options, click  beside the applicable parameter. For more information, see Transformer Parameter Menu Options.
Transformer Categories
FME Licensing Level
Search FME Knowledge Center
