You are here: KMLKMLRegionSetter
KMLRegionSetter
Sets the region-related KML attributes for a group of features destined for the OGCKML Writer.
Region Bounding Box
Display Criteria
Bounding Box Parameters
Example
The default settings will calculate a bounding box, and use that as the bounding box for the feature's region:
The inactive view shows that the feature is not initially displayed when you are zoomed out. The region is "inactive" and therefore the feature is not shown.
As you zoom in closer, the view meets the display criteria and the region activates; that is, the feature displays.
Additional References
For more information about KML regions and how Level of Detail is calculated:
Transformer Categories
KML
Search FME Knowledge Center
Tags Keywords: "Google Earth" KML
