SurfaceFootprintReplacer
                                        Replaces the geometry of a feature with a two-dimensional representation of the feature's shadow.
The output features are made of polygons with 3D coordinates. Any holes in the actual shadows are missing in the output features. The light source casting the shadows is considered to be infinitely far away.
This transformer accepts any feature, except those with null geometries.
Output features with replaced shadow geometries.
Features with null geometries are rejected.
Transformer
Overhead Shadow: The shadows are obtained from a light source directly above the features. The shadows will have a Z coordinate of 0.
Drop Shadow: The shadows are obtained from a light source located in a direction specified by the X, Y, Z parameters. The shadows will have a Z coordinate of 0.
Perpendicular Shadow: The shadows are obtained from a light source located in a direction specified by the X, Y, Z parameters, but are cast onto a plane perpendicular to the direction of the light source. Each feature's shadow is located near the original feature, so the shadows may not all lie on the same plane.
Light Source Vector Parameters
Coordinates representing the direction of the light source projecting the shadow. The light source is considered to be an infinite distance away.
The Z coordinate cannot be 0.
Transformer Categories
Search FME Knowledge Center
Tags Keywords: SurfaceFootprintGenerator
