You are here: ManipulatorsGeometryPartExtractor
Extracts or removes selected geometry parts based on a Geometry XQuery.
Note: For information about the FME geometry model, see FME Geometry.
Input Port
Geometry Part Selection
Note: Unlike other transformers that contain the Geometry XQuery parameter, this transformer requires that you specify a Geometry XQuery. If you want to extract every single part, one method is to use an XQuery that matches the "Hierarchy Position" to "Leaf Node". Alternatively, you can use a Deaggregator in hierarchy mode, which may produce more useful output.
Transformer Categories
Manipulators
Search FME Knowledge Center
Tags Keywords: GeometryPartRemover
