You are here: RastersRasterBandInterpretationCoercer
Alters the underlying interpretation of the selected bands of the raster geometry on the input features, using the specified conversion options.
For example, an input raster feature with a single band of interpretation UInt8 could be converted to a single band of Gray8 or UInt16 data.
  • Each RasterBandInterpretationCoercer performs a conversion on the input raster. If multiple RasterBandInterpretationCoercers are used in sequence, then multiple conversions will take place. Data quality and translation performance may suffer.
  • This transformer supports raster band selection. The RasterSelector can be used to modify the selection.
Related Transformers
Transformer Categories
Rasters
FME Licensing Level
Transformer History
This transformer replaces the RasterDataTypeCoercer and RasterColorModelCoercer transformers.
Search FME Knowledge Center
