You are here: RastersRasterBandSeparator
RasterBandSeparator
Separates the bands and palettes from each input raster feature into one or more output raster features based on the number of input bands and palettes.
  • The order of the input features and their bands and palettes will determine the order of the output features. A Sorter transformer may be used to enforce the order in which the features are processed.
  • This transformer is unaffected by raster band and palette selection.
Example
Transformer Categories
Rasters
Transformer History
This transformer was previously known as the RasterBandSplitter.
FME Licensing Level
Search FME Knowledge Center
Tags Keywords: raster grid band channel palette lookup LUT colormap colourmap divide separate split RasterBandSplitter RasterSplitter
