Adds a new attribute whose value is the number of holes in the feature. If the feature is not a polygonal feature, 0 will be returned.
 Input
Input
                                            Polygonal features enter through this port.
 Output
Output
                                            Features with the calculated number of holes leave through this port.
 Hole Count Attribute
                                            The name of the attribute that will record the number of holes in the feature.
Using a set of menu options, transformer parameters can be assigned by referencing other elements in the workspace. More advanced functions, such as an advanced editor and an arithmetic editor, are also available in some transformers. To access a menu of these options, click  beside the applicable parameter. For more information, see Transformer Parameter Menu Options.
Transformer Categories
Search FME Knowledge Center
