You are here: InfrastructureAttributeExposer
AttributeExposer
Exposes a series of hidden attributes, so they can be used by other transformers.
This transformer can be useful when dealing with transformers, such as the SchemaMapper, that dynamically add attributes onto features.
It is also useful if you know that features have hidden attributes (FME Attributes and the more obscure Format Attributes) that aren't shown in Workbench. You can use the AttributeExposer to "expose" these attributes.
This transformer is a more dynamic version of the Expose Attributes option in the context-menu of an input feature type.
Once the attributes are exposed, they can be used by other transformers.
The input features are not modified in any way.
Transformer Categories
Infrastructure
Search FME Knowledge Center
