You are here: Coordinate SystemsCsmapAttributeReprojector
Reprojects attributes from one coordinate system to another using the CS-MAP library.
Coordinate Systems
Vertical
Attributes
  • This transformer does not change the feature's coordinates – it only changes the values of the selected X, Y, and Z attributes (if they contain coordinate values).
Transformer Categories
Coordinate Systems
Search FME Knowledge Center
