You are here: RastersRasterCellValueRounder
Rounds off raster cell values.
Note: Note that floating point decimal values usually cannot be exactly represented. For example, the value 727.27 may actually be represented as 727.27002 when stored as a 32-bit floating point value. This property of floating point numbers may cause unexpected results when writing to text-based formats such as ESRIASCIIGRID. To avoid this, consider coercing floating point bands to real64 before using this transformer.
This transformer supports raster band selection.
The RasterSelector can be used to modify selection.
Transformer Categories
Rasters
Search FME Knowledge Center
