You are here: ManipulatorsArcPropertySetter
ArcPropertySetter
This transformer can also be used to create an arc by using a point as an input. The point geometry will be used as the center point for the new arc. When using this creation mode, you must supply, at minimum, the following parameters: Primary Radius, Start Angle, Sweep Angle.
Transformer Parameter Menu
Editing transformer parameters
Transformer Categories
Manipulators
Search FME Knowledge Center
