You are here: DatabaseSQLExecutor
SQLExecutor
Performs SQL queries against a database.
One query is issued to the database for each feature that enters the transformer. The results of the query are then output through the Result port.
Features that enter this transformer are not outputted until the SQL query completes. This behavior ensures that additional SQLExecutor transformers, if present, do not execute their queries until the previous query completes.
Relationship to FeatureMerger
The FeatureMerger joins two datasets and uses a simple, single attribute key to match features. The FeatureMerger is also able to perform certain geometric operations on incoming features using its Merge Type parameter.
Relationship to InlineQuerier
The InlineQuerier can be thought of as the crafty cousin of the SQLCreator/SQLExecutor transformers, in that it allows the power of SQL to be applied to datasets originating from non-SQL capable data sources or disjoint SQL-capable sources.
If all the data to be queried already exists in a SQL-capable data source, it is always more efficient to use the SQLCreator or SQLExecutor, because this allows the queries and filtering of the data to be executed directly by the database before it enters the FME environment.
Relationship to Joiner
The Joiner is very useful and efficient when there exists a one-to-one or one-to-many relationship between data flowing through FME and data held within a database. If it can be used, the Joiner can be more efficient than using either the InlineQuerier or SQLCreator/SQLExecutor, provided that the Joiner key fields have indexes in the source database. The Joiner is simple to use and does not require any knowledge of SQL.
Example
Transformer Categories
Database
Search FME Knowledge Center
