You are here: WorkflowFMEServerLogFileRetriever
Accesses the translation log for a specified FME Server-run translation. The translation log to access is identified by the job ID input parameter.
Dependencies
This transformer requires an FME Server connection.
The initiating feature is output via the Succeeded port if the translation log was successfully retrieved for the specified job ID, and will have these attributes added to it:
  • _log_attr: the contents of the translation log for the specified job
The feature will be output via the Failed port if the translation log was not successfully retrieved for the specified job ID, and will have these attributes added to it:
  • _job_failure_type: contains the reason for the translation log retrieval failure
  • _log_attr: the contents of the translation log for the specified job, obtained before an error occurred
Transformer Categories
Workflow
FME Licensing Level
Search FME Knowledge Center
