You are here: RastersRasterPaletteAdder
RasterPaletteAdder
Creates a palette from an attribute, and adds this palette to all selected bands on a raster.
Selected bands are required to have an interpretation of UINT8, UINT16, or UINT32. Note that palette entries will be discarded if they do not fit within the interpretation of a selected band. For example, when adding a palette to a UINT8 band, all keys that are greater than 255 will be dropped.
Format of Palette Attributes
See Format of Palette Attributes in the RasterPaletteExtractor.
This transformer supports raster band selection. Selected bands are required to have an interpretation of UInt8, UInt16, or UInt32. The RasterSelector can be used to modify selection.
Related Transformers
This transformer may be used in combination with the AttributeFileWriter to read a palette from a file. The AttributeFileWriter can read a palette file into an attribute, and this transformer can then create a palette from that attribute.
The RasterPaletteExtractor may be used to do the reverse operation and create a palette from a string attribute.
Transformer Categories
Rasters
FME Licensing Level
Search FME Knowledge Center
Tags Keywords: raster grid band channel palette lookup LUT colormap colourmap attribute add append read create
