You are here: Geometric OperatorsPathBuilder
PathBuilder
Connects input linear (arcs and lines) features in the order they enter, forming path features.
Note: For some datasets, it may be necessary to use a Sorter to order the data correctly before it enters this transformer.
If the end point of one input segment does not match the following segment's start point, a two-point line will be inserted between these segments in the resulting path.
Transformer Categories
Geometric Operators
Search FME Knowledge Center
