DropboxConnector
Using Dropbox’s file storage service, uploads, downloads, or deletes files/folders from a Dropbox account.
The output of this transformer will vary depending on the Dropbox Action performed.
- After an Upload action, URLs to the file may be saved to the Sharable Link and Direct Download Link attributes.
- A Download action can save to either a file or attribute.
- A Delete action will save the number of files/folders deleted to the Deleted File Count attribute.
- Finally, a List action will output a new feature for each file/folder found in the path specified. Each of these new features will have attributes listing various pieces of information about the object.
Features that cause the operation to fail are output through this port. An fme_rejection_code attribute, having the value ERROR_DURING_PROCESSING, will be added, along with a more descriptive fme_rejection_message attribute which contains more specific details as to the reason for the failure.
Request
The type of operation to perform.
Performing operations against a Dropbox account requires the use of OAuth2 authentication using a Web Connection. To create a Dropbox connection, click the 'Dropbox Account' drop-down box and select 'Add Web Connection...'. The connection can then be managed via Tools -> FME Options... -> Web Connections.
The remaining parameters available depend on the value of the Dropbox Action parameter. Parameters for each Dropbox Action are detailed below.
Dropbox Path
Path to a file/folder on Dropbox to delete.
Output Attributes
Specify the attribute that will store a count of the number of files/folders that were deleted.
Dropbox Source
The Dropbox path to the file to download.
Destination
Select whether to store the downloaded data in a File or Attribute.
- File: The downloaded object will be stored in the specified file.
- Attribute: The downloaded object will be stored in the specified attribute.
Specify the path to the file that will store the downloaded file.
Specify the attribute that will store the contents of the downloaded file.
Dropbox Path
The path on Dropbox to list the contents of.
Output Attributes
Specify the attribute to hold the name of an object on Dropbox.
Specify the attribute to hold the full path of an object on Dropbox.
Specify the attribute to hold the size of an object on Dropbox.
Specify the attribute to hold the revision string of an object on Dropbox.
Specify the attribute to hold the last modified date of an object on Dropbox.
Specify the attribute to hold the type (file or folder) of an object on Dropbox.
Source
The source of the data to be uploaded.
- File: The specified file will be uploaded.
- Folder: The specified folder and its contents will be uploaded.
- Attribute Content: The contents of the specified attribute will be uploaded.
When working with large objects, File is a better choice than Attribute Content as the data will be streamed directly from disk and not require that the object be stored entirely in memory on a feature.
The file to be uploaded to Dropbox if Upload from is set to File.
The folder to be uploaded to Dropbox if Upload from is set to Folder.
Choose whether to upload subfolders of the Source Folder or not.
The data to be uploaded, supplied from an attribute if Upload from is set to Attribute Content.
The encoding type of Attribute to Upload as File.
Dropbox Destination
The path on Dropbox to upload the source file to. To upload to the root directory, enter “/”.
The name of the file created from the data supplied in Attribute to Upload as File. The name must include a filename extension (e.g. .txt, .jpg, .doc).
Output Attributes
Specify the output attribute that will store a temporary publicly accessible URL that links to the file on Dropbox.
Specify the output attribute that will store a URL that links to the file on Dropbox. The URL can only be used by authenticated users.
This transformer cannot be used to directly move or copy files between different Dropbox locations.
Transformer Categories
FME Licensing Level
Search FME Knowledge Center
