Offsetter
Adds offsets to the feature's coordinates.
After you connect the transformer, you can enter parameter values as a number or pick the value of a feature attribute by picking Set to Attribute Value from the Parameter menu.
The feature will be shifted by the amounts specified.
The mode in which to offset feature coordinates.
Cartesian Coordinate Parameters
A separate offset must be set for each of the X, Y, and Z axes. If the input feature is 2D and a Z offset is specified, the feature is converted to 3D, and the Z offset is applied from a starting Z value of zero. If the input feature is a raster, only X and Y offset values will cause coordinate location shifts. The Z offset will cause the values in the cells of the raster to be offset by the specified amount for each selected band.
Polar Coordinate Parameters
The distance to offset the feature.
Angle in degrees CCW from the positive X-axis.
Spherical Coordinate Parameters
Angle in degrees CW from the positive Y-axis.
Angle in degrees from the XY plane. The angle between the XY plane and the positive Z-axis is 90 degrees.
Specifies a component to offset on point cloud features. Note that the x, y, and z components can be offset using the generic Offset values. This parameter is intended for non-spatial components (e.g. intensity).
The offset that will be applied to the corresponding point cloud component.
This transformer works with both raster and vector data.
This transformer supports raster band and palette selection. The RasterSelector can be used to modify selection.
This example shows an image offset using the x and y parameters:
Transformer Categories
Search FME Knowledge Center
Tags Keywords: raster vector coordinates offset pointcloud
