You are here: RastersRasterGCPSetter
RasterGCPSetter
Sets the Ground Control Points (GCP) on a raster with the specified Column (pixel), Row (line), X Coordinate, Y Coordinate and Z Coordinate.
If the raster has already set GCPs, the old GCPs will be overwritten.
To set a GCP
  • Set the source coordinate system.
  • In GCP Value, you must enter 5 values, separated with a space: Column(pixel) Row(line) X-Coordinate Y-Coordinate Z-Coordinate. For example,
1 10 50 -20 0
  • To set multiple GCPs, you can use a semicolon to separate each GCP. For example,
1 10 50 -2.5 0; 2 4 6 8 10; 1 2 3 4 5
Transformer Categories
Rasters
FME Licensing Level
Search FME Knowledge Center
