Open the reader Feature Type properties dialog and click the Format Attributes tab:
Locate the igds_linkage attributes and enable the checkboxes:
- Overlay transformations can optionally create lists of the attributes of the original features that were involved in creating each resultant feature. For an example, see Creating Lists Using Transformers in the FME Knowledge Center.
- When the Intersector notices overlapping line segments, it makes a list of all the attributes of the overlapping lines and adds this to the output segment.
- Both the Aggregator and ListBuilder may make lists of the attributes of features that they combine. The lists that are created by transformers such as these can contain very important information to be used in later processing.
