You are here: Workflows > FMEServerResourceConnector
Accesses the FME Server file storage service to upload, download, or delete files and folders or list information about files/folders from a FME Server account.
Jump to Configuration
  • Access data stored on FME Server file storage without using FME Server
  • Manage datasets on FME Server by uploading, downloading, and deleting files and folders
  • Transfer a file's contents (such as XML or raster) into or out of an attribute in FME
  • Read downloaded data using the FeatureReader, or upload data written by the FeatureWriter to FME Server
  • Retrieve file and folder names, paths, and other information from FME Server to use elsewhere in a workspace.
The FMEServerResourceConnector uses your FME Server account credentials (either via a previously defined FME web connection, or by setting up new FME web connection right from the transformer) to access the file storage service.
Depending on your choice of actions, it will upload or download files, folders, and attributes; list information from the service; or delete items from the service. On uploads, path attributes are added to the output features. On List actions, file/folder information is added as attributes.
  • This transformer cannot be used to directly move or copy files between different FME Server file storage locations. However, multiple FMEServerResourceConnectors can be used to accomplish these tasks.
  • The FeatureReader can access FME Server file storage directly (without using the FMEServerResourceConnector), however, a local copy of the dataset will not be created.
The remaining parameters available depend on the value of the FME Server Action parameter. Parameters for each FME Server Action are detailed below.
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies FME Server account
FME Licensing Level FME Professional Edition and above
Aliases
History Released FME 2017.0
Categories
Integrations
Web
Workflows
FME Knowledge Center
Search for all results about the FMEServerResourceConnector on the FME Knowledge Center.
