You are here: Attributes > AttributeRemover
AttributeRemover
Removes the selected attributes and list attributes from the feature.
Jump to Configuration
  • Cleaning up features with small numbers of unnecessary attribute
  • Improving performance by removing unneeded attributes
Once connected to input features, the AttributeRemover provides pick lists (one for attributes and one for list attributes) for you to choose which specific attributes to remove. All other attributes are kept, and the modified features are output.
  • Consider using the AttributeManager instead
  • Use the BulkAttributeRemover to remove all attributes that match a pattern.
  • Use the AttributeKeeper to keep selected individual attributes on a feature.
  • Removing attributes can improve Workbench performance, making translations run more efficiently and the Workbench interface respond more quickly.
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies None
FME Licensing Level FME Base Edition and above
Aliases ListRemover
History
Categories
Attributes
FME Knowledge Center
Search for all results about the AttributeRemover on the FME Knowledge Center.
