FME Parameters
FME parameters reference a specific FME system setting. Obtaining a value from an FME parameter is often easier than having to define a value at run-time.
FME parameters have various uses, including:
- Paths or folders might be used as a means to define the location of a file to be read during the translation; for example you might set an AttributeFileReader transformer to read a file from
($FME_MF_DIR)myFileName.txt
. - Other parameters might be used to control the action of a workspace, or direct features to different parts of a workspace in order to process them differently. For example,
FME_BUILD_NUM
could be checked to ensure the FME engine running the workspace is sufficiently new; this could be of particular interest on FME Server where multiple engines might each be a different build number.
FME parameters are listed in the table below:
Parameter | Description |
FME_BUILD_DATE | The date the installation running the translation was built. |
FME_BUILD_NUM | Contains the build number of the FME engine that is executing the workspace. |
FME_HOME | Expands to the folder where the FME executable resides. It includes a trailing slash, independent of the platform. |
FME_HOME_UNIX | Similar to FME_HOME, but in UNIX format |
FME_MF_DIR | Contains the name of the folder in which the current workspace resides. |
FME_MF_NAME | Name of the mapping file used for the translation. |
FME_PRODUCT_NAME | Name of this FME Desktop product release. |
See Also
