You are here: Geometries > LineCombiner
LineCombiner
Takes lines and connects them to form longer lines. Each connecting line must meet at the exact same start/end point, but otherwise they must not intersect.
Any nodes with only two lines connecting to them (sometimes called pseudonodes) are removed. Lines remain broken at points where three or more converge.
Note: Duplicate lines passed into the transformer will be consumed by the transformer.
Transformer
  • If the data might contain intersecting lines, consider running it through the Intersector before connecting this transformer.
  • On common vertices between combined lines, the LineCombiner maintains z-values and measures from the subsequent line.
Example
Related Transformers
Intersector
Transformer Categories
Geometries
Search FME Knowledge Center
Tags Keywords: connectivity ring PseudoNodeRemover LineJoiner
