You are here: Integrations > Curvefitter
Curvefitter
Note: The CurveFitter transformer is available as an extra-cost add-on from Safe Software. Please contact sales@safe.com or call 604-501-9985.
Smooths lines derived from line segments, points or raster data, and replaces a series of line segments with the optimal combination of straight lines and embedded arc segments required to create smooth curving lines. This process provides a truer representation of real-world features and can reduce file sizes by up to 80%.
In addition to processing simple line features, Curvefitter preserves feature topology when smoothing boundaries of adjacent area features.
Before the advent of enhanced geometry, FME was forced to stroke arcs into line sections to be able to process that data. Many other GIS packages that did not support arcs also ended up forcing the stroking of arcs, the net results being a great amount of data that could be represented by arcs but isn't. The Curvefitter transformer will allow a user to replace such stroked line segments with true mathematical arc segments. It will likewise permit the replacement of surveyed line features with an arc representation.
Dependencies
The Curvefitter transformer is based on linear optimization technology licensed from TCI Corp. It is available for purchase as an add-on to FME. Please contact sales@safe.com.
Curvefitter Applications and Functionality
Using the Curvefitter, you can:
  • Compress file sizes
  • Smooth jagged polylines
  • Process adjacent area features
  • Restore arcs in legacy data
  • Automatically process data
Example: Parcel Data
Procedure
A subset 6.1 MB Esri shapefile (provided by Grays Harbor County, in Washington State) was extracted and converted into four different formats: DWG file (3.8 MB), MapGuide SDF (4.5 MB), Esri Personal Geodatabase (5.4 MB) and ArcGIS 9.2 File Geodatabase (1.89 MB).
Each file was then processed using the following Curvefitter settings: Precision 0.1 feet; Flattening 0.1; Compression Weight 1; Smoothness Weight: 1; Accuracy Weight: 1; Preserve Shared Boundaries: Yes.
Parcel Data Test Results
Data Format Before Curvefitter After Curvefitter File Size Reduction
AutoCAD DWG 3.8 MB 1.6 MB 58%
MapGuide SDF3 4.5 MB 1.6 MB 64%
Esri Personal Geodatabase 5.4 MB 4.8 MB 11%
Esri ArcGIS 9.2 File Geodatabase 1.89 MB 1.07 MB 77%
External References
For more information and examples, please see:
Transformer Categories
Cartography and Reports
Geometries
Integrations
Search FME Knowledge Center
Tags Keywords: smooth smoother generalize generalizer
