You are here: Rasters > RasterBandNodataRemover
Removes the existing nodata identifier from the selected bands of a raster feature. That is, any values that were previously equal to the nodata value will now be considered valid data.
If a nodata value was not present, this transformer will not perform any action on the feature.
None.
This transformer supports raster band selection: see the RasterSelector.
Transformer Categories
Rasters
FME Licensing Level
Transformer History
This transformer was previously named RasterNodataRemover.
Search FME Knowledge Center
Tags Keywords: raster grid band channel nodata null void value remove delete flag RasterNodataRemover
