You are here: Attributes > BulkAttributeRemover
Removes all attributes with names that match a given regular expression. This transformer can be used to remove large numbers of attributes that have common naming patterns.
Jump to Configuration
  • Remove multiple attributes from features where the attribute names have something in common, such as a prefix, suffix, string, or a pattern that can be described with a regular expression.
The BulkAttributeRemover lets you enter a regular expression - which may be as simple as a specific series of characters, or as complex as you like, using Advanced Regular Expression syntax.
Any attributes with a portion of their name matching your expression are removed, and all other attributes pass through the transformer untouched.
Matches are case-sensitive.
  • Use the AttributeManager to remove selected individual attributes from a feature.
  • Use the AttributeKeeper to remove large numbers of attributes without expression matching, and keep selected individual attributes on a feature.
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies None
FME Licensing Level FME Base Edition and above
Aliases
History Replaces the AttributeExpressionRemover
Categories
Attributes
FME Knowledge Center
Search for all results about the BulkAttributeRemover on the FME Knowledge Center.
