You are here: Workflows > FeatureReader
FeatureReader
Reads features from any FME-supported format. A complete read is done for each feature that enters the Initiator port. The features resulting from the read are output either through named output ports or through the generic output port.
The features read can be constrained by specifying a WHERE clause or a spatial filter for formats that support them. Most reader settings and constraints can be configured dynamically from attribute values on the input features.
Additionally, a schema feature representing the feature type definition is output for each encountered feature type. The schema features can be used to configure feature type definitions for dynamic writing.
Reading
Reader
Select the Reader format and dataset, including any reader-specific parameters.
Constraints
Schema/Data Features
Enable Cache
Output
Output ports can be optionally generated for all or a subset of the feature types available to read. Features that do not have a generated output port will exit the generic output port. In order for output ports to be generated, the reader must be fully specified and accessible.
Attribute and Geometry Handling
<Generic> Port
Example
Transformer Categories
Filters and Joins
Format Specific
Spatial Analysis
Workflows
Search FME Knowledge Center
Tags Keywords: query Querier OracleQuerier RasterReader
