You are here: Data Quality > Matcher
Matcher
Detects features that are matches of each other. Features are declared to match when they have matching geometry, matching attribute values, or both.  A list of attributes which must differ between the features may also be specified.
Feature Elements To Match
Matching Options
Note: For surface and solid geometries, Interior Vertex Tolerance and Extra Vertex Tolerance are ignored and assumed to be 0.0. This transformer does not support surfaces or solids in the input if the Lenient Geometry Matching is set to Yes.
Output Attributes
Related Transformers
DuplicateFilter
The ChangeDetector provides an alternative (but less general) approach which may be more convenient for certain applications.
Example
Transformer Categories
Data Quality
Search FME Knowledge Center
Tags Keywords: pointcloud
