You are here: Spatial Analysis > NeighborFinder
NeighborFinder
Finds the Candidate features closest to each Base feature and merges their attributes onto the Base feature according to the Accumulation Mode parameter. Or, if Input is set to Candidates Only, performs the same operation using each Candidate as a Base feature, considering all other Candidates, but not itself.
If a feature is routed to both the Base and the Candidate input ports, then features will be compared to themselves as they are both a Base and Candidate.
If Input is set to Candidates Only, there will be no Base port. All Candidates will be compared with all other Candidates, but will not be compared to themselves.
Transformer
Attribute Accumulation
If attributes on the base and candidate feature share the same name, but are not geometry attributes that start with fme_, then they are deemed conflicted.
Transformer Categories
Spatial Analysis
Example
All angles are measured in degrees counterclockwise from horizontal. Where angles are not well-defined (for example, when a Candidate polygon is contained inside a Base polygon), they are set to 0.
This transformer works with 2D geometries only; if an input geometry is 3D, its z-coordinate will be ignored.
This transformer has full support for points, lines, arcs, ellipses, polygons, and donuts, and has limited support for other types of geometry. Polygons, ellipses and donuts may be processed as lines or areas, depending on user selection.
FME Licensing Level
Technical History
Associated FME function or factory: ProximityFactory
Search FME Knowledge Center
Tags Keywords: MBR "minimum bounding rectangle" neighbourfinder
