You are here: Rasters > RasterPaletteInterpretationCoercer
Alters the underlying interpretation of the palettes of the raster geometry on the input features, using the specified conversion options.
For example, an input raster feature with a single band with a single palette of interpretation RGB24 could be converted to a single band with a single palette of RGB64 or String data.
Each RasterPaletteInterpretationCoercer performs a conversion on the input raster. If multiple RasterPaletteInterpretationCoercers are used in sequence, then multiple conversions will take place; data quality and translation performance may suffer.
This transformer supports raster band and palette selection. The RasterSelector can be used to modify selection.
Related Transformers
The RasterInterpretationCoercer performs similar operations on the raster as a whole, such as converting 4 bands directly to RGBA.
The RasterBandInterpretationCoercer performs similar conversions on individual bands.
Transformer Categories
Rasters
FME Licensing Level
Transformer History
This transformer replaces the RasterDataTypeCoercer and RasterColorModelCoercer transformers.
Search FME Knowledge Center
Tags Keywords: raster grid band channel palette lookup LUT colormap colourmap datatype convert coerce adjust interpretation colormodel colourmodel bitdepth rescale scale
