You are here: Coordinates > LocalCoordinateSystemSetter
Tags all features with the local coordinate system defined by the specified parameters. It does not reproject features, or otherwise modify their geometry.
You should use this transformer if you know the feature belongs to a certain local coordinate system, but it is not tagged. This can happen if the feature is read from a format that does not store coordinate system information.
Local coordinate systems have the following limitation:
  • Z is not considered, so areas or distances are best preserved for geometry at an ellipsoid height of 0 meters.
Transformer Categories
Coordinates
Search FME Knowledge Center
