You are here: Strings > AttributeDecompressor
Decompresses and decrypts the values of the specified attributes that were compressed by the AttributeCompressor.
Jump to Configuration
The AttributeDecompressor lets you pick one, some, or all attributes on incoming features to be decompressed. If the compressed attributes have been encrypted, the password can be provided to decrypt them. Features passing through the transformer are output with their attribute names unchanged, selected values decompressed, and other values intact.
  • The AttributeDecompressor uses the zlib library to provide basic compression, and the OpenSSL library to provide encryption.
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies None
FME Licensing Level FME Professional Edition and above
Aliases
History
Categories
Attributes
Strings
FME Knowledge Center
Search for all results about the AttributeDecompressor on the FME Knowledge Center.
