You are here: Attributes > AttributeCreator
AttributeCreator
Adds one or more attributes to the feature and optionally assigns a value derived from constants, attribute values, and expressions. Values can reference adjacent features.
Jump to Configuration
  • Add a new attribute to a feature and assign it a value
  • Add a new empty attribute to a feature for use elsewhere in the workspace
Blank rows are provided where you can enter new attribute names and (optionally) set values for them. One or more new attributes may be added, and all features that pass through the transformer are modified according to these selections.
New attributes are added at the top. Duplicate names are not identified, and are not added more than once.
Dialog Options
Processing Behavior
Feature-Based
Exception: Enable Adjacent Feature Attributes
Feature Holding
No
Dependencies None
FME Licensing Level FME Base Edition and above
Aliases
History
Categories
Attributes
FME Knowledge Center
Search for all results about the AttributeCreator on the FME Knowledge Center.
