You are here: Rasters > PointCloudOnRasterComponentSetter
Sets point cloud component values by overlaying a point cloud on a raster. The component values for each point will be set from band values at the point location.
For example, a potential use case is to colorize a point cloud using orthophotos.
Transformer
Components
This transformer accepts multiple input point clouds and rasters. One point cloud is output for each input point cloud.
The component value for each point is taken from the first raster that can supply one (for example, if a point does not overlap a raster, the next raster will be tried), so the order of input for rasters can impact the result.
Transformer Categories
Point Clouds
Rasters
FME Licensing Level
Search FME Knowledge Center
Tags Keywords: point "point cloud" cloud PointCloud coerce LiDAR sonar expose extract extents orthophotos PointCloudOnRasterValueExtractor
