You are here: Rasters > RasterExpressionEvaluator
Evaluates expressions on each cell in a raster, such as algebraic operations or conditional statements.
Features are input through ports A and B. The cardinality of the input is required to be one of the following cases:
  • one or more As, no Bs
  • one A, one or more Bs
Note that the B port is only visible if Two Rasters is specified in the Mode parameter.
When both A and B features are provided, the single A input will be paired with each B input.
Note the following restrictions on input features:
  • Input features must have raster geometry.
  • All paired rasters must have the same number of rows and columns.
  • Either all bands used in the same expression must have the same nodata value, or all bands used in the same expression must have no nodata value.
  • No band may have a palette.
Note that when converting between different data types, a Bounded Cast is used. As a result, when a calculated value does not fit in the specified destination interpretation, the corresponding destination value will either be set to the minimum or maximum value possible in the destination data type.
Transformer Categories
Calculated Values
Rasters
FME Licensing Level
Search FME Knowledge Center
