You are here: Point Clouds > PointCloudExtractor
PointCloudExtractor
Serializes the geometry of the feature into the Blob Attribute based on the selected writer format.
  • The PointCloudReplacer may be used to do the reverse operation and convert the encoded blob back to the original data.
  • Alternatively if the point cloud is not required as a geometry on the feature for future processing, the AttributeFileWriter transformer can be used to dump the Blob Attribute directly to a file.
  • To carry out a similar operation on vector data, please use the GeometryExtractor transformer. For raster data, please use the RasterExtractor.
  • Currently supported formats include:
    • ASPRS Lidar Data Exchange Format (LAS)
    • ASPRS Lidar Data Exchange Format Compressed (LAZ)
    • Cesium 3D Point Cloud (pnts)
Transformer Categories
Point Clouds
Related Transformers
PointCloudReplacer
GeometryExtractor
GeometryReplacer
RasterExtractor
RasterReplacer
FME Licensing Level
Search FME Knowledge Center
