You are here: Attributes > AttributeDereferencer
Copies the value of an attribute whose name is referenced in the source attribute. The value is added to a newly created attribute.
Example
Suppose you have two attributes:
  • Attribute A has the value B
  • Attribute B has the value 999
In the transformer parameters:
  • Set the Source Attribute parameter to A.
  • Create a new Destination Attribute called newAttr.
When you run the workspace, the value 999 (from Attribute B) is added to the destination attribute, as shown in the log file:
2010-11-27 18:13:38|   0.1|  0.0|INFORM|Attribute(string)        : `A' has value `B'
2010-11-27 18:13:38|   0.1|  0.0|INFORM|Attribute(string)        : `B' has value `999'
2010-11-27 18:13:38|   0.1|  0.0|INFORM|Attribute(string)        : `_newAttr' has value `999'
Transformer Categories
Attributes
Search FME Knowledge Center
