You are here: Spatial Analysis > CenterLineReplacer
CenterLineReplacer
Replaces an area feature with its medial axis or a straight skeleton. This transformer works best with long, narrow areas.
  • Unexpected output may result if input polygons self-intersect or have duplicate vertices.
  • Because Z coordinates are not considered in either algorithm, all features processed by this function are forced to 2D.
  • If non-area features are passed to this transformer, they will not be changed, and they are logged with a warning.
  • Donuts that contain holes that touch will produce incorrect output.
  • If vertices are very close together unexpected output may occur.
Example
Transformer Categories
Geometries
Spatial Analysis
Related Transformers
When combined with the Tester, this transformer enables FME to perform area generalization operations.
Search FME Knowledge Center
Tags Keywords: abstraction simplification simplify centerline centreline CentreLineReplacer
