You are here: Filters and Joins > DatabaseJoiner
DatabaseJoiner
DatabaseJoiner: Joins attributes from an external table to incoming features as they are being processed through a translation.
The DatabaseJoiner queries an external table to retrieve attributes associated with a feature. One or more feature attributes are joined to one or more columns in a table in the database, and the values from the matching table row(s) are added as feature attributes.
The _matched_records attribute specifies how many records in the database the feature matched to.
The DatabaseJoiner is a very powerful transformer with many performance-related settings.
Reader
Join
Merge Attributes
Optimize
Tip: Where DatabaseJoiner transformers will match only on a known subset of records within a table, it will often be more efficient to prefetch that subset of records before matching takes place.
Relationship to FeatureMerger
The FeatureMerger joins two datasets being read in a workspace. FeatureMerger is also able to perform certain geometric operations on incoming features using its Merge Type parameter. FeatureMerger performs all joins in memory, so it can be faster than the DatabaseJoiner if you have more than one relationship on the same data. DatabaseJoiner joins are performed by the database using SQL. The article FME2011 Use Case: Joiner vs FeatureMerger contains a more detailed comparison of these transformers.
Relationship to InlineQuerier/SQLCreator/SQLExecutor
The DatabaseJoiner is very useful and efficient when there exists a one-to-one or one-to-many relationship between data flowing through FME and data held within a database. If it can be used, the DatabaseJoiner can be more efficient than using either the InlineQuerier or SQLCreator/SQLExecutor, provided that the DatabaseJoiner key fields have indexes in the source database. DatabaseJoiner allows simple join relationships based on multiple attribute keys and requires no knowledge of SQL – this is often very effective for simple lookup tables. SQLCreator/SQLExecutor allow more complex joins and these are executed by the source database.
The InlineQuerier is useful in cases where data sources have no SQL ability, or for more complex queries. The InlineQuerier allows you to ask more sophisticated questions about the data than the DatabaseJoiner.
Example
Transformer Categories
Attributes
Filters and Joins
Search FME Knowledge Center
