You are here: Coordinates > ReprojectLengthCalculator
Converts a given distance from one coordinate system to another. The transformer calculates the reprojected length of a line starting at the first coordinate in the feature, with the given length and angle. Both the length and angle parameters are specified in the source coordinate system.
This transformer is useful for converting data such as text heights and widths that are measured in many systems in the destination coordinate system units.
Transformer Categories
Calculated Values
Coordinates
Search FME Knowledge Center
