You are here: Point Clouds > PointCloudTransformationApplier
Applies transformations on a point cloud.
Applying a transformation is primarily done for compatibility with other processing and writers that cannot support the transformation natively. For example, the LAS reader produces Int32 coordinates with a scale and offset. However, the POINTCLOUDXYZ writer cannot support component scale/offsets, so the transformation will be applied. The resulting coordinates will be Real64 with no transformation. Note that processing and writers that cannot support transformations will apply them automatically, but this transformer can be used to manually apply the transformation if desired.
Transformer Categories
Point Clouds
FME Licensing Level
Search FME Knowledge Center
