You are here: Geometries > LineExtender
LineExtender
Creates two-point extensions to linear features that extend the feature by a user-specified length.
This transformer can also output the original feature with the first and last segments stretched by a user-specified amount. Each of the created features gets a copy of all attributes of the original feature, including the feature type. Arcs that are input are converted to lines before processing.
Example
Transformer Categories
Geometries
This transformer can be used in combination with the Snapper to perform a simple form of data cleaning.
FME Licensing Level
Search FME Knowledge Center
