You are here: Integrations > MRF2DCleaner
MRF2DCleaner
Note: The MRFCleaner transformers are available as an extra-cost package from Safe Software. Please contact sales@safe.com or call 604-501-9985. This package includes all MRFCleaner transformers.
MRF Geosystems Corporation (www.mrf.com) has produced cleaning software and made it available to FME users to apply to data as it is transformed between arbitrary input and output formats.1Portions of this work are the intellectual property of the MRF Geosystems Corporation and are used under license. Copyright © 2006 MRF Geosystems Corporation. All rights reserved.
The MRFCleaner repairs geometry, particularly during data migration from CAD to GIS, and is built upon the MRFCleanFactory, which is an integration of MRF’s cleaning technology into FME. The MRFCleaner fixes geometric problems in input data such as line overshoots and undershoots within the user-specified tolerance. It is useful for multi-layer and multi-tolerance two-dimensional data cleaning. Typical applications include the correction of utility maps, parcel maps, topographic maps and resource maps as data is migrated from one system to another.
The MRFCleaner includes the following functionality:
  • fuzzy tolerance
  • extending lines
  • weeding lines
  • joining lines
  • processing short elements
  • removing gaps
  • removing duplicates
  • removing dangles
  • performing conflation
The number of layers used in cleaning the data is determined by the number of different cleaning tolerance values of input features. Features that have the same cleaning tolerances are processed as being on the same layer. This allows feature data from a high-quality data source to be assigned a low cleaning tolerance and integrated with data from a lower-quality data source which would be given a larger cleaning tolerance.
Geometries such as path, polygon, donut, ellipse, elliptical arc, multi-area, multi-curve, text, and multi-text are converted to basic geometries such as point, line, path, arc or multi-point prior to the cleaning process. The cleaner understands and works with circular arcs. Input features with invalid geometries are ignored and deleted.
Usage Tips
You can also use one more of the following transformers to perform singular MRFCleaner operations. These transformer parameters are all available as part of this MRF2DCleaner transformer, but you may wish to use separate transformers so that the operations are more easily visible in your workflow.
MRF2DConflator
MRF2DDangleRemover
MRF2DDuplicateRemover
MRF2DExtender
MRF2DGeneralizer
MRF2DIntersector
MRF2DJoiner
MRF2DShortGeometryRemover
Transformer
Geometries
Module Workflow
MRFCleaner Modules provide more detailed information on the modules in the underlying MRFCleanFactory.
This Closeddefault workflow is suitable for most situations. However, using the individual modules, it is possible to create any number of customized workflows for specific projects and/or datasets (for example, in Workbench, by using a series of consecutive MRFCleaner transformers or custom transformers). It is important, however, to understand the data being processed and the desired end result.
More Information
Transformer Categories
Data Quality
Integrations
Search FME Knowledge Center
Tags Keywords: MRFCleaner2D
